Totally stumped. Next stop is a real mechanic
achris
More fish than mountain goat
Re: Totally stumped. Next stop is a real mechanic
Its a parlor trick! Advancing the throttle with the motor cold simply moves the idle speed screw off of the cam which attaches to the choke, allowing the spring in the electric choke to close the choke butterfly. Doesn't matter what you do with the throttle after that, the spring will hold the choke shut until the spring warms up, expands, and moves to open the choke. Moving the throttle to full advance then back will work the accelerator pump and squirt fuel into the carb.
It does actually. There is an adjustment called 'choke pull off' It sets how far open the choke plate will be pulled back at full throttle when the bi-metal spring in the choke assembly is cold.
WSKIPPER
Agree with achris....hold the choke open and see if the engine run improves...remember...it was fine BEFORE you messed with any screws....
eavega
Just to put this thread to rest, I did finally end up taking it to a mechanic. I was having such a hard time just keeping the motor running long enough to attempt an adjustment, and such a limited amount of time ( I can only work on my motor after work, and no later than about 7:30 b/c I have neighbors with small kids) that I figured it would take me a week to get the motor running right. The mechanic charged me $200 and he verified my work on the ignition conversion, removed and inspected the carburetors (clean), re-installed and verified operation, set the idle speed and mixture, set the idle timing, cleaned and verified gap on the plugs, and verified the choke settings. He did discover that my console Tach is about 300 RPM fast as compared to his shop tach, so that was another good take-away. Given that when I had it running right my original problem was I needed to crank down the idle speed to set the timing correctly, this whole expense could've been avoided if I had used the proper tool in the first place (a reliable test tachometer instead of the optical tachometer)
In any case, the mercruiser is now purring like a kitten. No shake, no fouling. The mechanic did comment on the engine and how it is in excellent overall shape. he told me he had worked on the same motor of much more recent vintage and that those are nowhere near in as good condition as my motor is.
Next stop is the lake. Lanier hit full pool yesterday, so its going to be a spectacular boating season (hopefully)
Rgds
MarkSee
Sounds like $200 well spent and now you're set to go. Seems like that's a mechanic to use again.
Mark
