torquing pattern for 40 hp johnson model #40EL 71G
airman141
I want to install heli coil repair into my 1971 40 hp Johnson spark plug hole. I want to remove head and install. Does anyone have the bolt torqueing pattern and gasket part number for this outboard? Thanks in advance!
F_R
Honorary Supreme Mariner
OEM part number 307069, or Sierra Marine number 18-2957 here at iboats. Start with one of the center bolts and tighten to half torque. Then the one next to it, then continue outward in a spiral pattern. Repeat at full torque 168-192 INCH pounds. Retorque after test run and cool-down.
airman141
Thanks for the quick response! Maybe I can still be on the lake for opening week end!!
