torqueing down 140 hp head
J.Todd
Hi fellas. thanks for all the previous info, re cylinder head gasket. I am now ready to replace everything. I am waiting for the Library to get me the Seloc book, but in the mean time where can I go to find the torque values and the sequence of both the head and the manifold. thanks Jim
J.Todd
Re: torqueing down 140 hp head
Hi. I have finally replaced the head and torqued it down. The manifold is on and the push rods are installed. I have # 1 cylinder at tdc and I am going to adjust the valve lash according to the downloaded manual and a previous post. I have a problem. How do I tell the exhaust valve from the intake when I have all the parts on. Thanks. Jim
Ayuh,... The intake valve lines up with the intake port, 'n the exhaust valve lines up with the exhaust ports of the manifolds...
Don S
Re: Valves
Re: Valves
Valve layout is E-I-I-E-E-I-I-E
You first have to make sure you are on #1 TDC on the compression stroke, and if you had the timing gear marks lined up, you are NOT on the compression stroke. Here is from the manual, be sure to follow it.
Note: you will also need to be at #1TDC on the compression stroke when installing the distributor.
Crank engine with starter or turn over in normal direction of rotation until mark on
torsional damper lines up with center ?0? mark on timing tab, and engine is in No. 1 firing
position. This may be determined by placing fingers on No. 1 valve as mark. If valves
move as mark comes up to timing tab, engine is in No.4 firing position and should be
turned over one more time to reach No. 1 position.
The next biggest mistake made is getting the free travel out of the rocker arms.
The manual states
Loosen adjusting nut until lash is felt at push rod, then tighten adjusting nut until all lash
is removed. This can be determined by moving push rod up and down while turning
adjusting nut until all play is removed
This is where most people overdo it and get valves too tight.
When you are moving the push rod up and down and tightening the rocker nut to zero lash, when the push rod stops moving, stop tightening. Do this one time and one time only, do not recheck it, the push rod will move again, but don't mess with it. You are done finding zero lash.
Now turn the adjusting nut the additional amount called for in the manual. Here again, use the value in the manual not what someone else says they use. This process does nothing more than set the hydraulic lifter at mid point in it's working travel.
I merged both of your posts together. Please do not double post a question in two different threads.
J.Todd
Hi. Thanks for all the info and sorry about the double thread. Jim
J.Todd
Hi. Not sure that I'm doing this right, but want to continue the thread. I have adjusted the valves, but just not sure that it is right, so will do it again. 2 questions. 1) after getting O lash, I know that there should not be any up and down movement, but can there be side to side movement. 2) after adjusting the last 3 valves, will some of the previous ones adjusted be loose or did I not do it right. Thanks for the help. Jim
Don S
Then back off all the adjustment nuts about 3 turns, then start over.
When you are moving the push rod up and down, you will be centering it at the same time. While you are moving the push rod up and down with one hand, tighten the nut with the other. Tighten just to the point that the lifter stops moving up and down. Forget side to side. Then STOP checking for zero lash. Then tighten the additional amount and move on to the next valve. Don't over think it.
Sure they will be loose. Once you get the engine running and oil pressure, things will be fine.
J.Todd
Hi. Thanks again. I have never down this before, so all the help I get is really appreciated. Jim
