top end issues
marchelg
I have a 2017 Lund 1875 with a 115 MERC PRO XS. With the motor down it will top out at 4300 RPMs and 38 MPH. If I trim the motor up I can get up to top RPMs but my top end still is only 38. Anyone else have the problem. Dealer and Lund says that is just the way it is
jimmbo
Speed by gps or water pressure Speedo? Does the bow rise as the engine is trimmed out/up? What prop are you running?
Sea Rider
That issue is due because prop blades are not getting top water thrust when OB is trimmed up or even down. Prop blades should rev perpendicular to water level to get the max out of them. It's like swimming with open fingers..Optimum OB/transom height also plays its role for top prop thrust doing its homework right.
Happy Boating
porscheguy
What is ?top rpm?? Mercury puts the WOT range on this engine at 5300-6300rpm.
Do you have a command thrust gearcase? What is your gear ratio?
What hole is your o/b mounted on? Engine height is important on o/bs.
