Top Dead Center Tool -DIY
Berdink
I made my own, but my distance between mark A and mark B is 5 inches. My TDC Mark on my flywheel and pointer line up just like they should.
My thinking is my DIY TDC Tool works fine since all we're trying to do is find two reference points in the #1 pistons up travel and down travel. Then halfway between my two marks I make is True Top Dead Center.
Am I missing something?
Am I right?
piston stop, pointer and a degree wheel and you can find TDC on any engine
Crosbyman
I have used a sishkabob stick ..you can feel the piston reversing just after TDC
Captain of the Double G's
I like that ! You can use the stick to barbecue shrimp while figuring out how to buy something for boat and not tell wife or justify it.
Me, wife did not like that , I still have my Starcraft :)
who needs a big house anyway ? seriously, years back I tried to find TDC with a screwdriver, got broken and stuck in block. That small stick will burn up and not cause engine failure.
Berdink
I have used that method with automotive engines, but I figured the piston stop tool would be more precise for this outboard that likely has less tolerance.
