Tool Functions Explained !!!!
kenmyfam
Anyone have or used any of these ???:D:D
DRILL PRESS: A tall upright machine useful for suddenly snatching flat
metal bar stock out of your hands so that it smacks you in the chest and
flings your Coke across the room, denting the freshly-painted project
which you had carefully set in the corner where nothing could get to it.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under
the workbench with the speed of light . Also removes fingerprints and
hard-earned calluses from fingers in about the time it takes you to say,
'Ouch'
SKILL SAW: A portable cutting tool used to make studs too short.
PLIERS: Used to round off bolt heads. Sometimes used in the creation of
blood-blisters.
BELT SANDER: An electric sanding tool commonly used to convert minor
touch-up jobs into major refinishing jobs.
HACKSAW: One of a family of cutting tools built on the Ouija board
principle... It transforms human energy into a crooked, unpredictable
motion, and the more you attempt to influence its course, the more
dismal your future becomes.
VISE-GRIPS: Generally used after pliers to completely round off bolt
heads.. If nothing else is available, they can also be used to transfer
intense welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various flammable
objects in your shop on fire. Also handy for igniting the grease inside
the wheel hub out of which you want to remove a bearing race.
TABLE SAW: A large stationary power tool commonly used to launch wood
projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground
after you have installed your new brake shoes , trapping the jack handle
firmly under the bumper.
BAND SAW: A large stationary power saw primarily used by most shops to
cut good aluminum sheet into smaller pieces that more easily fit into
the trash can after you cut on the inside of the line instead of the
outside edge.
TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength of
everything you forgot to disconnect.
PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids
or for opening old-style paper-and-tin oil cans and splashing oil on
your shirt; but can also be used, as the name implies, to strip out
Phillips screw heads.
STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used to
convert common slotted screws into non-removable screws and butchering
your palms.
PRY BAR: A tool used to crumple the metal surrounding that clip or
bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to make hoses too short.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is
used as a kind of divining rod to locate the most expensive parts
adjacent the object we are trying to hit.
UTILITY KNIFE: Used to open and slice through the contents of cardboard
cartons delivered to your front door; works particularly well on
contents such as seats, vinyl records, liquids in plastic bottles,
collector magazines, refund checks, and rubber or plastic parts.
Especially useful for slicing work clothes, but only while in use.
SON-OF-A-***** TOOL: (A personal favorite!) Any handy tool that you grab
and throw across the garage while yelling 'Son of a *****!' at the top
of your lungs. It is also, most often, the next tool that you will need.
achris
More fish than mountain goat
Re: Tool Functions Explained !!!!
Yeap, relate to ALL of those!!! :D:D:D
Topol_86
I can relate to all!:) just turned this from forum into viral e-mail FWD....alot of my friends i'm sure will no doubt get a good laugh. cheers!
Tim Frank
Used all of them, own most of them...except the "HOSE CUTTER".
I do own a "PIPE CUTTER" which I suspect is similar and could be used if you needed to shorten a hose "just enough"....;):D
HVAC Cruiser
Well that explains a lot but you didn't mention
Easy-out - Designed to break inside bolt you used pliers and vice grip on rendering part totally useless
Arc welder- used with shaky hands designed to changes eye color and simulate the feeling of sand kicked in your eyes
Bob_VT
What about the
LOST/STOLEN TOOL? The one you look for and give up and try to make another tool work........ and you see it laying in the middle of the bench at the end of the day....right where you left it.
kenmyfam
What about the
I think I have several of those !!!!:D:D
DECK SWABBER 58
:DGREAT LIST:D
Pickax: Used to locate water line you weren't looking for.
Bob_VT
I have given in to getting older..... I now have a habit of asking my wife to help me find the lost things..... I have to say she has ninja locating skills and usually saves my butt!!! :D
Tim Frank
Is it hijacking if I add a few to the list?...:D
Electric Hand Drill: Normally used for spinning steel Pop rivets in their holes until you die of old age, but it also works great for drilling rollbar mounting holes in the floor of a sports car just above the brake line that goes to the rear axle.
Timing Light: A stroboscopic instrument for illuminating grease buildup on crankshaft pulleys.
Battery Electrolyte Tester: A handy tool for transferring sulfuric acid from car battery to the inside of your toolbox after determining that your battery is dead as a doornail, just as you thought.
Trouble Light: The mechanic's own tanning booth. Sometimes called a drop light, it is a good source of vitamin D, "the sunshine vitamin", which is not otherwise found under cars at night. Health benefits aside, its main purpose is to consume 40-watt light bulbs at about the same rate that 105-mm howitzer shells might be used during, say, the first few hours of the Battle of the Bulge. More often dark than light, its name is somewhat misleading.
Air Compressor: A truly Global machine that takes energy produced in a power plant 200 miles away, burning Pensylvania coal, and transforms it into compressed air that travels by Malayan-rubber hose, to a Chicago Pneumatic impact wrench, that grips rusty suspension bolts last tightened 40 years ago by someone in Detroit, Michigan, and rounds them off.
Grease Gun: A messy tool for checking to see if your zerk fittings are still plugged with rust.
JustJason
ROUTER
A rediculously high speed tool that is designed for molding contours into wood. Secondary purpose of the razor sharp bit is to strip flesh and muscle from bone, and to wittle bone down to the marrow.
Also usefull for sending router bit bearings flying at 30,000+ rpms and 100MPH. Projectile similar to 9mm bullet
Jeep Man
'Ouch'
blood-blisters.
outside edge.
your palms.
Seems like you have been by my shop:rolleyes::D
BTW, thanks for the info on Sea and Ski.
PiratePast40
And don't forget the multipurpose cresent hammers and screw chisels. You get to invent your own uses!
JaSla74
100% agree. My wife seems to find everything that's right in front of my face now.
kend301
Glad to see this post ... For all these years I thought I was using tools wrong !
Also let's not forget :
The Adjustable Wrench .. Great tool to use to confirm that your health insurance covers broken knuckles .
Impact Driver / Hammer ... Used to get a few days off after your vacation time has run out for the year.
