Re: Took boat to get winterized now have a cracked lower unit
Id be checking the block too !! drives get water in them , bad seal , or whatever , all Im saying is if the drive was oil was changed at the time of the rest of the winterization , the void would have been found before damage occured !!!
If there was water in the drive when the customer brought the boat in, how can that be the maintenance shop owners fault?
Water in the drive IS DUE TO A PROBLEM IN THE DRIVE (leaky seal, etc) NOT because the shop didn't change the oil "fast enough" or immediately.
Now if the boat was brought in to be winterized, the boat sat outside (at the dealer) and the shop didn't drain the water out of the block and the block cracked while the dealer had the boat, that would a different situation!!
But it's not normal for a drive to have water in it. IT"S NOT THE SHOPS FAULT that the drive has a crack in it whether the drive had water in it or not......(unless you can prove the drive WAS NOT cracked, AND you knew it had water in it, AND TOLD THEM to drain the water out of the drive.........)
