Too much gas in motor
mot007us
I have a older 100 hp javelin 4 cylinder motor, spark plugs are covered in gas, still runs, but goes blah, blah, blah. Any ideas?
Vic.S
Your description suggests the carbs are probably flooding causing the wet plugs and " four stroking"
You dont say what year or give the model number but assuming fixed jet carbs I would be looking at the floats and/ or the needle valves.
Chinewalker
100 Javelin would be early 1980s. I'd bet your carbs are due for a rebuild, particularly if the gasket between the bowl and carb body is black. New kits have a brown or light green gasket there. Make sure the float level is set correctly, too.
Also, check compression.
mot007us
Thank you for the information, I am going to try to find a diagram of the motor, to get a better idea, of what you are talking about, because I am nervous about working on carbs. I found the model number and year, it is a 1979 100 hp, 4 cylinder model number 100tlr79s, also what is the best gas to put in it.
Vic.S
Honorary Supreme Mariner
Post compression numbers on that crossflow.----Picked one of those up for parts a while ago , wanted the cover / cowling which was in nice condition.
mot007us
Thank you everyone for your help and the diagram and manual will really come in handy, Vic
