TOMOS motor
vparris
I bought my first motor used. It is a Tomos 4.9 and I broke off part of the prop. Then I found out the company that made it went bankrupt and now I can not find a prop to replace the one I broke. Does any body know where I could find one? <br /> Thanks, Ms. Wave Maker
stevens
Re: TOMOS motor
Welcome to iboats, Ms. Wave.<br /><br />Seems you are not alone in your predicament - unless of course you & Ms. Parris in this other thread are one and the same:<br /><br /> http://boards.diynetwork.com/groupee/forums/a/tpc/f/2711916776/m/9671045142/r/5461004342 <br /><br />Also, a few Tomos engines for sale on this other site. Some of these sellers might be able to find you a propeller.<br /><br /> http://www.boatsandoutboards.co.uk/page/text/boat/uk/8/ <br /><br />This one in particular: http://www.bosunsmate.co.uk/ailsa_craig.htm <br /><br />Otherwise, a good prop shop will probably be able to fix the prop you already have.
vparris
Re: TOMOS motor
Thank you for your response. I found some Tomos engines on the web sites and sent some email out.Yes I am Ms. Parris also. You can see how desperate I am. Instead of being a desperate housewife just call me the desperate boater.
stevens
Re: TOMOS motor
Are there no good prop shops in your area? Might save you some time & effort, instead of trying to find a non-current prop from a bankrupt manufacturer from a country that no longer exists...<br /><br />Maybe you could take a few pictures of the prop you have and post them here. The guys here would be able to say whether or not it is fixable.<br /><br />Or, maybe you could try this online prop shop: PropMD
malagaoth
Re: TOMOS motor
if you have just broke a blade off try castle marine in caernavon(wales) they should be able to fix it
stevens
Re: TOMOS motor
I believe she is in South Carolina.....
