Welcome back Vintin,
So with a 12 pitch achieved 5200 rpm and 32 MPH and with a 12 one achieved 6000 rpmand 32 MPH. The less pitch you go after, the higher the revs that will rev up along max MPH slight decrease.
Would advise not to rise the engine, leave it for water flow to skim right under small upper plate where possible, raising the engine from where now sits will increase wot rpm, reduce max MPH speed a bit as there will be less water bed height for prop to get the max thrust.
If wanting middle response between both props send to a prop shop the 13 pitch and have it repitched to 12.5 or the 12 pitch to 12.5. Should gain, lose +,. 400 wot revs going for any of both ways. Have you realized that with a 12 pitch the hole shot is way faster than with the 13 one.
Another prime example that one less pitch will never gain + 200 wot revs if going per the idiotic rule of thumb...
To get the max out of the combo assume that is run with 2 up as the last posted pic, the engine is trimmed to sit at 90 deg and water flow is passing right/close to upper plate, right ? If yes on all 3, stay there.
Once ideal transom/engine height is dialed, it's only a matter to play with prop pitches. repitching must be done when1 full pitch is too much and only need to play with 1/2". Most times those sizes are very hard to get or even be market available.
BTW, don't do anything to the hull, just have it clean, mirror like, shinny cond to slide efficiently on water. Engine height optimization along a correct prop maximization is the way to go.
Happy Boating
