Tohatsu Control Box
tightstripes
I'm in the process of buying a used boat from somebody. I picked it up last monday and he gave me a week to have it checked out and take it for a sea trial. I picked it up from the mechanic on Thursday and when towing it home, the center console tipped over. The remote control box with the tilt/trim broke. The plastic in the throttle lever is cracked and wont go into reverse and barely goes into drive.
Anybody know roughly how much a new control box will cost (part & labor?
This something i can easily put in myself or does it need to be wired??
Do I need the tohatsu control box or can i get a generic?
Where is a good place to find these online?
temple1975
Re: Tohatsu Control Box
Start here, these guide's will give you a good idea how to hook up your controls. Just find your model. If you don't find your model just go with the eqivalant hp.
http://www.tohatsu.com/tech_info/manuals.html
I just saw a couple of these units on ebay. If not you might try http://craigslist.org or goto the manufacture's website and find your local dealer. http://www.tohatsu.com/outboards/index.html
If you find a good unit you can (with the help of the owner's manual) remove the wires /cables one by one and install them on the other unit one by one.
tightstripes
Is it possible to just replace the throttle lever? It has tilt/trim wired into it.
Tampa Ron
i picked up a generic remote control box with the tilt/trim in it for under $150 new. dont know where you are located but i am in the Tampa St. Pet area. good luck
