Scots-Andy
Thread starter- Joined
- Jul 26, 2008
- 2
I have a 90hp direct injection 2008 model tohatsu 2 stroke. I am currently operating it from the back of a large zodiac based in northern Canada. I struck a rock with the tips of the propellor blades, this took a ?cm gouge out of the blade-tip from two (of three) blades. Unfortunately the stress propogation also caused severe damage to my drive chain and lower casing.
The entire lower casing cracked open around the drive chain bulge, instantly draining all the oil and exposing the gears. Not only the casing but also the drive chain itself suffered damage - the area where the horizontal driveshaft mounts into the aluminum casing, behind where the gears mesh with the gears for the verical shaft, has numerous cracked parts and broken pieces. The gears themselves are absolutely fine, no missing teeth, anything. When I removed the propellor and the top locking bolt the entire bottom of the motor, from the drivechain down simply fell off into my hand along the crack. The strike occured as the motor was barely engaged in forward gear, the boat was travelling at approximately 4 knots (we had just left harbour). Only the tips of the propellor hit, the leg, the lower casing and the skeg don`t even have a scratch. The drive chain seems to have exploded through the aluminum lower casing - clearly seen by the outward bending metal.
I have never seen or heard of such severe damage to a motor from a minor prop strike. Until this engine purchase i have never used a tohatsu. I was lead to believe that a whole load of safety features are built into the motor to stop gear and drive chain damage from prop strikes.
The engine requires an entire lower leg replacement. has anyone heard of any aluminum case defects on Tohatsu lower leg units? Or has knowledge of the safety systems installed on the engine designed to prevent this from happening?
The engine had been used for 10 hours prior to this happening, all oil and fluids were full and everything was working fine.
Any help would be appreciated!
Cheers
Cheers
