FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
Just adjust bolt tigh against shaft untill you have prop nut cut alligned with shaft hole so to lock split pin into shaft. Prop must not play back and forth once correctly adjusted, but it's normal to find some lateral play on shaft while props sits well adjusted.
