Tohatsu 70c
Texastoon
Changed oil in foot, looked a little blue in color. Concerns?
Also noticed no rubber washers on the plugs. Do I to get some before putting in the water for a test.
Thanks
pvanv
Re: Tohatsu 70c
Sounds like the LU lube was blue when filled. Should not be a big deal; There are lots of colored lubes out there.
The drain/fill plugs should have gaskets. A generic should work fine, or you can get the OEM fiber seals from any Tohatsu/Nissan dealer.
