Tohatsu 4 stroke 9.8 exhaust just got a lot louder
Sailordog
Hello all, my 2009 4 stroke Tohatsu ( MFS9.8A3) exhaust just got a lot louder, as in if it was my car I’d be looking for a hole in the exhaust pipe. It still runs normally, no chocolate milk in the oil, and nothing I can detect as an exhaust leak in the engine compartment. I still get exhaust out of the above water port along it a normal water telltale and thru prop exhaust .
problem is same whether engine is cold or hot.
any help with idas are most appreciated.
pvanv
Verify the timing. You can use a timing light. If the gear belt jumper a tooth, the valves could be opening late.
Sea Rider
With use and heat all gaskets will cede in a bit, adjust tight with wrench all the bolts located under the pan, if bit lose exhaust will be heard louder than when factory delivered, check.
Happy Boating
Sailordog
Great ideas, I’ll give them a shot.
yes, salt water - sorta, upper Chesapeake
thanks to everyone
