Balthazar
Thread starter- Joined
- Jun 30, 2013
- 7
Hi folks!
I have bought a used Tohatsu MFS 2.5A 4-stroke 2007 and was pretty happy with the overall condition of the engine, very lightly used! When started first time, the waterflow from the cooling system was very strong and permanent. I have changed the oils and the prop, every time testing the engine again. I saw the flow from the pee pipe was becoming less strong each time I was running the engine. Finally, I went on the canal for about 1.5 hour on an inflatable dinghy Intex. The waterflow was less and less strong and finally stopped. Just drops. This caused the engine stopping 3 times, probaly overheated (it was progressively losing the power, and I needed to add the throttle till half to still run it at a very low speed) and having removed the engine cover, to allow it cooling a bit, I went back home.
I've checked the water pump impeller and it looks very fine, no obstruction in the lower unit as well.
So, do anyone have an idea about this issue and how I possibly could deal with?
Many thanks for help.
