junglerat007
- Jul 27, 2014
- 8
I have a 17 foot Marlin Glasscraft, with a semi rotten transom. I got the whole boat and motor for free. Spent 500$ on getting the motor tuned and working. It had a blown stator and the guy before me had used Dryer cable from a house to power it from the battery. Now I see that the transom is getting a little rotten. Have thought about getting another boat, but all the ones in my price range will probably be in similar shape. The boat has no other problems and can out perform a lot of other newer boats with bigger motors. Have done a circle around a striper while it was full out with a 90 hp Yamaha 4 stroke. I have an 88 65hp commercial evinrude. I have been toying with the idea of taking the low transom I have, that constantly is taking water in because of where the cables come out. I want to raise the transom to the top of the gunwales and pod it. I have been looking at building a fiberglass pod and putting the motor 18" back and a bit higher. Some have said it would be fine. My Father an engineer tells me the boat wont work right due to it flipping since I have moved the pivot point back and it will do catwalks or worse. I want to believe that a pod will solve all my problems. From the water splashing in to repowering down the road with out redrilling my transom. Might be able to get an aluminum pod but that is a dream. Would like to cut out the low transom gut, ie the part above where my gas tanks are and have 12 more inches in my boat. Would put a bow mounted gas tank in or maybe an in floor, depends what is available. Thoughts or guidance would be appreciated. PS someone out there please prove my Dad wrong.
