To buy or not to buy...
webb
I am looking at a 1979 85hp mercury outboard with the following compressions: 125 95 125 125 125. Should I walk away from this engine because of the 95 compression? The engine is represented as having good spark and operational but it is not in a boat for testing.
Laddies
Banned
Re: To buy or not to buy...
All 850 built after the early 60s are 4 cyl. What ever it is it's beyond the 10% differance between cyls. that recommended. If the engine has been sitting around it could be stuck rings that might lossen up but not knpwing it could also be a bad cyl wall and the engine would be junk. Your money, your spin of the wheel!
Scaaty
I'd pass on a low cyl too...it being 70's, could be a leaking/cracked exhaust/water jacket, which is letting water into the cyl (takes little water), and rusting a ring, hence, 95psi..it will get worse as it does in the wall.
And as they have no removeable head (I'm pretty sure yours is), the crank and all must be pulled for a hone/bore
Tadd_P
agreed leave that motor in the hands of whomever has it. He probably wouldnt be selling it if it were in good working order!
webb
Thank you Gentlemen for your collective wisdom...time to look for another engine.
