Tire help
prayingmantis
I recently bought my first real boat. It is a 1988 19' Blue Fin Sportsman 1950. The tires that are on it are 175/80/13. They are rated at 1350 lbs. My boat weighs 1650 lbs. What size and wt rating should I have. Thanks for any help
coolbri70
Re: Tire help
those tires should work, leaves you 1050 pounds for the trailer and gear
roscoe
Re: Tire help
Welcome to iboats.
The tire weight rating on the sidewall is per tire.
So if each tire is rated at 1350, times 2 tires = 2700#
boat 1650
gas 150
battery 50
gear 150
trailer 500 ?
Total weight of approximately 2500#, so you have a 200# cushion.
