Tips on care for a Boaton Whaler
paintitup12
Does any1 have tips for taking care for a Whaler? i got a 9fter and besides knowing to scrub it....I NEED HELP!!!!!!!!!! The paint is flaking and barnicles are on it. Im probaly just going to repaint it because i dont have enough money but im going for good paint. Im wondering if the color affects the fishing and if a different color will effect have soon it will flak. Im going to sand it really good too though. Is there different types? ISince i have a
9fter im wondering if that narrows it down.
paintitup12
My Boston Whaler is flaking!!!!!!!
The fiberglass i think is either flaking or the paint. Its an old boston whaler(sorry no pic) and i leave it on my boat ramp
ondarvr
Re: My Boston Whaler is flaking!!!!!!!
What is flaking off?
Gel coat doesn't normally flake off unless there are very big problems with it. Paint will flake off a poorly prepped surface easily, so the answer to your question depends on the source of the problem.
A pic would be great too.
D
DJ
Guest
Re: Tips on care for a Boaton Whaler
Several Whaler owners/fans here on iboats, including me.
What are you trying to do?
Bob_VT
Send JB the moderator here a PM ....... JB is our resident whaler pro and has had quite a few of them
D
DJ
Guest
I also have a Whaler and have restored another.
paintitup12
i just want to no how to get it back to tip top shape. its (flaking) and i think im suppose to repaint it is this true?
paintitup12
I dont no to much about it a nieghbor gave it to me. The inside at parts seems to be flaking. i think its the paint. I cant tell im trying to get a pic
I just want to no how to make it look better
Sand it out,+ Repaint it......
njlarry
First weigh the hulll and check that against factory spec. The inner foam in BWs can get water logged weekening the hull. The gel coat never flakes, only paint and paint needs repainting.
D
DJ
Guest
Agree. It must have been painted at one point.
paintitup12
thx ill try and if the bottom has barnicles do i just scrape them off wont that hurt the boat can i repaint the bottom?
JB
UGH!! :(
What I would do is remove all paint, including paint on the wood if there is any. Then I would restore the gelcoat finish and varnish the mahogany. If you only want to make her servicable sand and repaint with high quality paint.
The story about Boston Whaler foam getting saturated is mostly myth. The foam is closed cell, but water can intrude between the foam and the hulls and wet the foam surface. I have had two Whalers that were supposedly saturated. I drained the water between foam and hull, sealed them up and used both for years.
You need to give us more information in one thread rather than the same information in several threads.
Windykid
It would be a good idea to preasure wash the bottom and see where you are at. You might find there are some cracks that need fixing before you paint. I would preasure wash as much paint of the inside and restore the gel finish like JB said. It might be a lot of work but the older Boston Whalers look great. Good luck!:)
paintitup12
thx it actually was made i think as a sail boat it has a place 4 the mast
paintitup12
the boat was made i think 85 sooo plus it is like made as a sail boat but has a miny transom
JB
I think what you have is a Boston Whaler Squall. It was intended to be a tender or a sailing pram. The sail kit, I think, was optional.
paintitup12
I think your right my motor barely fits on the "transom" so im thinkin bout repainting it then put some plastic on it. I dont care if it cracks just as long as the boat doesnt:)
njlarry
Not so sure it's a "myth". Several respected friends on the boston whaler continuous wave site have detailed various model whalers with hundreds of pounds of water in the foam. They have reported long involved methods to drain with limited success and severe damage from freeze/thaw cylces. It is certainly a very rare problem but before restoring one I'd weigh it first.
Windykid
Would like to see a pic of this boat, to aid in your restoration.
