Recently my boat has had an occasional misfire at mid speed and then the boat shuts off. Ive described it as if I am running over rocks but I believe that its just a misfire on my 1996 150hp Ocean Pro Evinrude. Today I popped the hood off and started looking to see if there is anything obviously wrong. <br /><br />On the right side of the motor there is an arm with a roller that opens the carbs once the throttle gets to a certain point. It appears as though this advancement is in sync with the advancing of the timing.<br /><br />What I noticed is that there is a clearish yellow rubber cover over this roller which is split from top to bottom with a large piece missing completely. In my driveway with the motor off I pushed the throttle foward and noticed that this split in the roller allows the roller/bar for the carbs to drop into this split area which means that the carbs are not as open as they normally would be but the timing still advances normally. Could this cause the timing and carbs to be out of synch and could this cause a misfire? Is this bad roller a possibility and is it common?
