Timing Question
stump1234
No Title
well I bought this gage of of ebay same brand as mine paid 20,00 for it. I have the rpm set at 650 is that correct. and picking up the cable tomorrow, they said seastar 600a series will fit.
achris
More fish than mountain goat
Very nice.... And a great price... :thumb:
stump1234 said:
I have the rpm set at 650 is that correct...
Spec says 650+/-50, so yes.... Just remember, that's not a 'shop tacho', and it no more than an indication. For checking idle and WOT you should be using a calibrated tacho.
Chris..........
stump1234
Very true on calibration, I was concerned abut it running so high at idle when I got it there would be no way to put it in gear. When I first start it I have to warm it up a little with the throttle but she holds good and doesn't die, rebuilding the fuel pump really did the trick.. and splicing into the regulator was a fantastic idea. Thanks again for all your help.
achris
Hopefully once you get that new shift cable in you can go fishing and enjoy the fruits of your labour. :D :D
Chris.....
stump1234
No Title
tried the grease but its so far down its hard to put the needle bearing in place
An outboard mechanic would clean the bearing with say laquer thinner.---He would then intall those needles with grease from the bottom-------Never a problem doing it that way.
stump1234
Thanks I was able to put grease down the hole and put grease on the needle bearing and flat tip screw driver and push all eighteen bearings in.. I thought I was doing surgery.. haha Thanks
stump1234
Now I have no spark what would cause that? control module,stator? I have a mercury 150xl ot961925
stump1234
well I have sparks to all six plugs and 115 compression on cylinders and plugs are wet with fuel but engine will not start.. fuel, air, spark what am I missing?
stump1234
Has anyone shimmed a 2004 mercury 150 XL SWB OT961925 outboard lower unit Pinion gear.
I placed the lower bearing shim into the driveshaft housing bore and placed the lower bearing race into housing gear and retainer.. But all that did was to get excessive play from the shaft since the shim is pushing up on the bearing cup and not the bearing.
