sltintexas
Thread starter- Joined
- May 28, 2010
- 109
I have a question on timing a 96 mercruilser 3.0LX with EST ignition. I am a little stumped on the a few lines in the manual.
the following is from Service Manual #13 page 4b-25
If you look at the picture attached, Do I have the correct connections circled in red? Connect the purple wire to the wht/grn wire (female purple to male wht/grn).
I also know about the jumper wire needed at the distributer..that part I understand.
3. Bypass the shift interrupt switch by disconnecting wires at shift interrupt switch. Temporarily join the engin hardness wires together.
