lucky7's
- Jul 9, 2008
- 74
Re: Timing Problems
Yea I did zero lash and then you do 360 degree turn after zero lash. I cant start and adjust because the exhaust manifold has to be removed to get the valve cover off. However I think i figured out the problem.. The rotor tang has to be aligned to the arrow mark before you slide the distributer shaft in and ive been tryin to align the tang and arrow after the shaft is in.. And ofcourse because of the helical gears the rotor tang is going to spin forward some when it slides in.. That dang manual is so obscure... Think i got it now will try tomorrow... Just hope i didnt screw my engine up tryin to start it with the timing off.... Jeesh
