Timing pointer?....
Tinlizzy
I went to adjust my timing the other day on my 71' 1150 (115 hp) merc.
After I pulled the cowlings off and the top cover I noticed no timing pointer? There is a tape on the flywheel with the timing mark but no pointer that stands out at me?
I did see what looks like a pin hole on the distributor magneto pulley. Do I somehow use that to set the timing? :confused:
Or is the timing pointer missing on my motor? Is there a way I can rig something up if it is missing to adjust the timing?
Re: Timing pointer?....
Tin, On those early motors, the timing mark was cast into the upper cowl support. The timing pointers came later '74??.
You can put a piece of tape on the upper cowl support and mark it for TDC, if the original mark is missing or wrong.
Tinlizzy
thanks for the help Chris :)
I will check this out.
