Timing decal on fly wheel
skully
I can not synchronize primary pickup,maximum advance, and maximum throttle adjustments because the timing decal on the flywheel are unreadable. I need an illustration of the timing decal. I have looked everywhere even in my repair manual please help.
fone_man
Re: Timing decal on fly wheel
What have you got.......... Make & model please.... This whole board is about info, info, info... more the better!!!<br /><br />We can't see it, we can't touch it but we can darn talk about it if you provide the info...<br /><br />Waiting on your reply........<br /><br />
<br /><br />------------------<br />"Keep It Between The Bouys" & "Good Luck"!!!<br /><br />fone_man
skully
I'm sorry, I have an 850 mercury serial#4370369 and the timing decal is made of paper. It is worn so much that I can't read it. I was also wondering when you finsh the dial indicator setting is the pointer supposed to be on TDC. And thank you for your reply.
12Footer
two things you can do. Go to a cooperative boatyard,and ask to be given access to one,and trace it.<br /><br />But I would remove cylinder1 plug, insert a scewdriver and turn engine by hand to the point where the piston is all the way up. This is top dead center,regardless of what the decal claims it is. Now, picture the flywheel as a pie with 360 slices. Each slice is a degree. The rest is math and a timing light.<br />I hope this helps ya get back on the water.
