jwolfie001
Thread starter- Joined
- Jun 14, 2008
- 15
Hi all,
You guys have not let me down so far so I am returning for more guidance. I recently have had to add lots of oil after a day of boating. As I searched for the source of the leak, I noticed that oil would "puddle" in the bilge right under the harmonic balancer. Immediatley I start to expect the oil pan, timing seal or timing cover gasket. So off I go to obtain an engine hoist ($125 on CL including an engine stand), the needed gaskets and was even lucky enough to pick up a new impact to make the the job go quicker. Ah, all is well in life. Until . . .I pull the balancer only to find most of the bolts holding the timing cover on are almost rusted away. No sweat years ago i bought a bolt out set in case I would ever need it. Get all of the bolts out to discover that the timing cover has holes around the sides. So now I ask, where is the best deal on a timing cover? The local "Stealer" offered one for over $250, and I have found one on ebasicpower.com for about $120. It is my understanding that this engine was very common and that I should be able to use a cover for one of its relatives such as the 250 inline six or the 2.5 liter pontiac engine. C'mon fellas, you've been lights out so far. Don't disappoint. Thanks
