Timing belt broke, HELP !
jeff wilson
I have a 1964 60 HP Evinrude. When replacing the timing belt there are timing marks on the top of the engine and the flywheel to line up. There is also a mark on the distributor pulley but i can't find anything to line it up with. Thanks if you can help.
12Footer
Re: Timing belt broke, HELP !
Not sure, but if it's like most timing chains and belts, the mark is top dead center #1.<br />I would get a knowlageable second opinion tho.
adrian bick
There is a mark on the groove of the pulley, there is a mark on the opening of the housing ,there is another mark on the distributor housing. 5 marks to line up.
jeff wilson
Thanks Adrian I'll check it out in the morning and let you know how i did.
