Timing a 1976 85hp.johnson v4
Ron.M
What is the procedure for setting the timing on this motor ?. Before doing this I Should explain the problem, I Adjusted the throttle cables hopeing to get more speed, instead I lost power, I ajusted back to its original position and still can only get one third speed at full throttle what happend ? HELP!
crazyray2
Re: Timing a 1976 85hp.johnson v4
bet something came loose on either carb linkage or advane linkage.......see if both are getting full travel.......if they are go to basics.....compression, fuel and spark.......it just a process of elimination........good luck......
