Re: timing? 76 6hp evinrude
The timing does not require being set. That is aligned by the woodruff key in the crankshaft which keeps the flywheel and its associated magnets where it/they belong(s). As long as the flywheel key is not sheared, the engine is in time.<br /><br />The engine does have points and are to be set at .020. Align the fiber rubbing portion of the points with the flywheel key when setting them.
