captbarnaclebill
Thread starter- Joined
- Nov 24, 2003
- 2
Tried it by the manual with no luck. At idle the Idle timing is at 8 degrees BTDC and it should be 1 degree ATDC. The small knurled timing adjust knob cannot be turned far enough to achieve correct number unless the idle screw and the throttle cable adjustment is screwed in a long ways which then causes a fast idle and the inability to throttle all the way back down. The first step in the manual says to pull back throttle to neutral and if it does not touch the idle screw then the cable length should be adjusted till the arm touches the idle screw but it does not tell me where the idle screw should be initially. TDC on the piston correlates to the timing mark on the flywheel (what are the extra set of timing marks on the flywheel to the left of the apparent correct timing marks?) It is a vicious circle between correct idle speed and correct timing, I cannot achieve both at the same time. The top cylinder is #1 isn't it?
