TIlting mechanism for 1981 Evenrude 70
wellington4
New boat owner, used boat. I cannot figure out how to disenge the engine lock so I can tilt it up to bring it out of water. Can anyone please guide me through this.
Texasmark
Re: TIlting mechanism for 1981 Evenrude 70
Long time ago...er ah er ah.......on the tilt there should be a thing you can get ahold of, call it a circular hootus with a flat bar across it so that you can turn it one way or the other. Will either be on the bottom of the piston/pump assy, or on the motor assy. This is the fluid bypass. With it bypassed....probably turned 90 degrees from normal operation, the tilt fluid will bypass the tilt piston and you can tilt the engine manually.
Best I can do.
Mark
