Tilt Trim
delume01
I have a 2003 Evinrude 200 that trims up just fine but slowly clicks down. The rams seem sealed in. My question is can I access the internal sections of hydraulics to change seals? Fluid levels good and no leaks. Any help would be greatly appreciated.
boobie
Re: Tilt Trim
Is your manual release valve tight ?? If it is, that's where the problem might be. Bad manual release valve.
