Tilt & Trim
newbieyong
Hi all, I have a 1975 85 HP Mercury on an Starcraft A15. I found a tilt motor on the boat and the up and down control buttons however, I can't find a hydraulic lift and when I push the up/down buttons nothing happens. Does this motor come with built in hydraulics? where would it be and what does it look like?? Thanks alot..
mystro
Re: Tilt & Trim
I'd suggest getting the manual..it's always well worth it even if it only keeps you out of the shop once.
Chris1956
Re: Tilt & Trim
That motor would have trim cylinders just outboard of the transom clamp bracket. Four hosess would have run from the pump to the cylinders.
