Tilt Trim Switch and relay
bcamp2009
I have a 1983 140 hp Johnson but I do not have the switch or relay for the tilt an trim unit, is there a simple way to wire this up?
Barnacle_Bill
Re: Tilt Trim Switch and relay
You need to get the switch and relays. The relays are required to handle the higher current the tilt motor requires.
ezeke
http://www.maxrules.com/graphics/omc_pics/T&Twiring.gif
Used, pre-wired PT&T relay boxes are nearly as common as dirt around salvage yards; just buy one.
sea-way.com
outboard-parts.com
laingsoutboards.com
tcoutboard.com
fairwindsmarina.com
salvagemarine.com
marinepartsoutlet.com
outboardexchange.com
Superior Marine (800-338-9281)
budgetboats.net
americanoutboard.com
piratemarinesalvage.com
trixieslanding.com
mmmarinesalvage.com
bcamp2009
Thanks for the info.
The wiring diagram is great I was having hard time finding one.
I appriciate you taking the time to help.
Thanks
Brian
