Tilt Trim still doesnt move
87Chap
1988 johnson gt 150 i installed a brand new tilt trim motor today and the engine still wont move. you can hear the motor working like its suppose too. did i just not put the fluid in correctly or does it still have air in the lines. im so confused at what i need to look for next. :confused:
jonesg
Re: Tilt Trim still doesnt move
if the manual release valve is not really tight it will pass fluid from one side to the other without moving the engine.
doghunter9
it should be a flat head held in place by a c-clip down around the trim motor(may even say manual release). Turn it in all the way and try again
