Tilt & Trim removal?
dwsides
anyone know the trick to taking of a TT motor on a 98 115 with fasttrac sys.?
i can get to 3 bolts but looks like the engine has to be pulled to get the last one.
blimp
Re: Tilt & Trim removal?
on my '87, i had to remove the entire T&T unit to replace the motor. its not too bad, and easier than pulling the whole engine if you don't have a lift or cherry picker.
Happy_Jack
You need to remove the entire TnT unit in order to access that screw/bolt.
Many people have cursed that design (including me)
Release the manual tilt screw, lift the motor, engage the manual uplocks.
Remove the tilt pin, remove the upper tilt ram pin, disconnect the wiring, remove the (6 I believe) bolts holding the TnT unit in the transom brackets, or remove the lower pivot pin (if equipped) and slide the unit out.
I remember having to slide the bottom out first, then tilt as you go, and it all clears.
Generic, but it worked for me.
