Traded my 14ft pontoon with a 35hp for a 24ft pontoon that needed carpet and deck, with 50hp evinrude. It’s in pretty rough shape, but he said motor runs but it was dismounted and laying on its side on deck. So far I’ve stripped everything down to just the toon logs and cross bars. But I decided to mess with motor and it runs but shifter box is messing some things and not sure what else. It’s also a electric shift with buttons to change gear to forward, neutral, and reverse. Not a big fan of that but whatever. But it has tilt and trim that doesn’t work. I took it apart and it was rusted and a wire had come undone from one of the brushes. I connected wire back and clean it up as good as I could. Put it back together and it work!!! Went down.. then went up and nothing... then wouldn’t go back down. It won’t move now. It seems to have power cause I have it running straight to battery. It’s a 3 wire. But i took it apart again and same thing happened. Went down but won’t go up. Then now nothing. Not sure what’s wrong?? Any help??
