Re: tilt/trim problem
Thanks very much for your replies. At this point, I'm assuming that the trim gauge is a separate issue from the trim failure. I took a longer look at the trim failure over the past weekend. <br /><br />The fluid is definitely topped off. I added a couple of ounces of 10W-30 last fall to top it off. The maintenance manual says that 10W-30 is an okay substitute for Quicksilver trim fluid. However the fluid in the reservoir now seems milky in appearance (kind of like coffee with cream in it) and texture (viscosity is more like cream than oil). <br /><br />There are two lines leading from the pump to the lower unit. Is one line a return to the trim pump? I'm asking because one of the lines appears to either be completely clear of fluid, or it might contain the fluid that I'm seeing in the reservior. The other line appears to contain the darker, oily fluid that I expected to see in the reservior.<br /><br />Can water infiltrate the trim system and cause the fluid to lighten like lower unit lubricant does when water infiltrates the lower unit?<br /><br />The trim pump is original equipment. I use the trim frequently when under way. The boat probably has well over 200 hours on it although I don't have an hour meter. I don't trailer the boat other than at the beginning and end of the season.<br /><br />If the trim pumps needs to be replaced, or the lines need to be bled, is this something that can be done in the water or do you need to have the boat on land? Is this work something that a weekend type mechanic could do, or is it better left to a pro? I always do basic maintenance (oil, filters, plugs, lower unit, winterizing, etc...)to my boats, but always leave the bigger jobs to the pros. <br /><br />Any more help would be greatly appreciated.
