Tilt/trim Problem
nbmako
i have a 1995 johnson 115hp motor. The tilt/trim works great out of the water and at low rpm cruising thru the harbor, my problem is, once i get outside the breakwater, tilt/trim does not work. If i slow down, i can raise it but as soon as i give throttle you can see it slowly lowering back to original ( bottom) position. I have put fluid in, but without a site glass i cannot tell if it full or not or even if this my problem. Any help or suggestions would be appreciated.
thanks greg stephens
Haywood123
Re: Tilt/trim Problem
Sounds to me like either your pump is going or one of your pistons is leaking.
