Tilt trim possibility
rainman01
Hello,
I have a '89 Force 50hp on a Bayliner Capri. It does not have tilt/trim, and I would like to add it to the unit. I am totally ignorant on the subject and am looking for any info at all. Type of unit needed? Can one even be added? Single cylinder? Info on install? Any help at all wou8ld be greatly appreciated.
Thank you,
Dennis.
jerryjerry05
Re: Tilt trim possibility
Yup they sell them on e-bay all the time.They are easy to install.
Stay away from salt water units.
Make sure when you buy you get the solenoids and wiring
Your control wiring cable already has wiring built in for T/T.
You will need to install a switch on the dash or it might already be in the shifter.
Location?
rainman01
I have seen a number on e-bay, have not bought because of concerns as to weather or not they will work on my boat. If by location you are asking where I am at I am in northern minnesota. There is not a tilt/trim on the control but I work in the boating industry and am aware of a number of controls that would either dash mount or mount anywhere. I am happy to know the control wiring would already have the necessary wiring. Is there a way to know which units would cross to my motor? I have seen complete used units in the $300.00 range, with plate. Just need to be sure it will mount on mine.
Thank you for your help.
Dennis.
jerryjerry05
Very easy to mount.
The unit must be for a 40-50hp The ones for 85/125 won't work.
If you find one send us the link and I'll see if it's right.
Sent U a PM
