Rstacy
Thread starter- Joined
- Sep 22, 2017
- 33
My boat is 1979 Baja with a Merc 90 on it. Last year the tilt/trim motor started stalling. I would tear it down, find nothing and it would run again for a bit. Both up and down solenoids are good and full voltage is getting to the motor. It got so bad that I drilled a small hole in the end bell so that when it stalled out on the water I could stick a piece of music wire in the hole and move the armature. This would get it running again.
I finally purchased a NOS (new old stock) motor reservoir pump and all was good for a couple of months but now the new pump is doing the same thing. The solenoids click, the motor is getting the full 12 volts but the motor doesn't turn. With this pump if I let it sit for a day it will start running again.
Before I buy a new pump for $400 am I missing anything here? Are there any better pumps that will accept the 4 lines for my two tilt cylinders?
