Tilt/Trim Issuei
cuellaraj
I have a 2004 Johnson 115 HP J115PLSRC and having a problem with the Power Trim/Tilt. I bought this boat several months ago and the trim and tilt was working. The third time I took it out the switch on the throttle would not work. I run across a switch on the motor and was startle by the motor as it raised. This is the first time I own a boat. I checked the continuity on the trim switch by the throttle and it works fine. I had already bought a switch since the switch on the motor worked and I came to the conclusion it was the trim switch. Can anyone shed some light as to what the problem might be? I was told the relays are working since the switch on the motor raises and lowers the motor. Would the sending unit be the cause. It also does not have a gauge. I have ordered SELOC Repair Manual with no results of the problem. The motor works fine except for this isssue. Thanks
Will Bark
Before you condemn the throttle trim switch make sure the connections from the control box are still connected securely and are good.The sending unit has nothing to do with trim and tilt. Others should chime in with other suggestions. Good luck.
cuellaraj
Yes the three wires from the control box fit into a triangular connector and is on securely I checked the wire coming from the other end and I am getting electricity from it. I do not know if it is a good idea to check those for continuity because I' m afraid to short something. Thanks for the info and for your service.
vdwusa
I've got 4stroke 115 and the switch in the bow, side of the hood, and throttle are all fine. With a real strong person lifting any 'up' will take it up. So, I was thinking low on fluid. I loosen the cap and there is fluid to the top of the hole. what's my next move? Any help much appreciated.
vdwusa
On a trim tilt for the 2004 115 4 stroke, You can pretty much bypass any switch by jumping inside wire of the three to either outside wire, right? I did so, results didn't change....when I have the motor all the way lifted, the fluid is even with the peep hole in the cylinder. Motor doesn't want to go up on it's own. How do I manually do this?
Chris1956
Honorary Supreme Mariner
I have much the same issue on the "down" side of my throttle mounted trim switch. The motor cowling switch works perfectly and the throttle trim switch works perfectly going "up". The "down" throttle-mounted switch tends to get out of position, not allowing the switch to be pushed properly. I think the fix is to replace the switch, or adjust the stainless steel keeper that holds the switch in the proper position and take care when operating it. Since the switch is hard to get and expensive, I chose the latter.
