Hello All and thanks to the community!
I have a 1994 Evinrude E70TLERC that has some tilt problems...
Original problem was that I couldnt get the motor to trim up or down on either the throttle switch or the motor mounted switch.
Eventually, I discovered that if I remove the cover and tap on the relays, I would get a response out of both switches and the motor would tilt both up and down.
Since then, I have been running the boat and lived with the fact that I'd have to tap on these relays to get a response.
I decided to order new relays thinking that was the problem and since then the replacement worked for a few runs but now the tilt will only work in the up position and with a little coaxing (lifting) of the motor.
Sometimes I dont get any response from either switch...
Where should I start?
I should also mention that the "Sending Unit" (picture attached part #83) arm broke off (part #88) and the wiring is in bad shape.
Let me know if you need more information.
Thank you guys!
Thank you guys!
