MickLovin
Master Chief Petty Officer
- Feb 18, 2013
- 822
Well I finally got my tilt trim motor, and found that the bloke when he pulled the valve body off has scored the sides of the reservoir causing it now to leak around the base of the reservoir. Could I just get away with a new seal or should I change out the reservoir part of the pump, as I have a spare reservoir??? Pain in the *** really as I just got it on the boat after taking those 3 bolts off and replacing the old reservoir and motor, only too find I should have swapped just the motor part not the reservoir to avoid the leak. Will a new rubber o-ring surfice and seal it you think?
