tilt problem
sthao7
i have a 3.0l omc cobra. my hydrolic isn't lifting my motor up. does anyone know why or knows how to manually lift the motor up.
WillyBWright
Re: tilt problem
I know of no manual method other than disconnecting the rams at the rear pin so at least you can trailer it with the drive tied up. Make sure you have enough fluid if the trim unit runs but doesn't lift. Check your Up solenoid if all you hear is clicking. Check your switch if nothing happens at all (could be the Up solenoid too).
sthao7
Re: tilt problem
the tilt works fine down but not up. once in a while the tilt up will work. but most of the time it doesnt. could it be electrical problem?
