I have have a 2006 SeaRay that is suddenly having issues with the tilt on the MerCruiser outdrive. When I tried to put the outdrive down, it did not respond and the radio cut out for a few seconds. Also, the horn did not work but all other electrical items seem to work as expected. Some of the times when I use the tilt/trim toggle switch there was a clicking noise, other times there was nothing. I have never had any issue with it in the past. I tried wiring directly from the battery to the trim motor and there was a clicking noise, but but no movement of the outdrive. I checked the fuses and for any obvious wiring issues. Thoughts?
