SignwaveJack
Thread starter- Joined
- Jan 16, 2009
- 1
Hi Folks,
The tilt motor on my 1996 120 Force sometimes continues ruinning after I have raised it a bit. The motor just keeps going up by itself. And when it reaches it's limit, it keeps running. I have to quickly hit the battery kill switch to keep it from going up endlessly - and prusumably destroying itself.
When it is going on like this, jiggling the trim switch on the throttle does not stop it from continuing. Also, just killing the batteries and waiting a while does not fix it ...
So, when this happens, I switch off the batteries - then I unplug the 2 wires in the engine compartment that go to the trim motor. I jiggle the trim switch again for luck. Turn on the batteries - and then reconnect the 2 wires for the trim motor. (all in that order). After that, it starts working again.
This trim motor was replaced about 2 years ago. Could anyone venture a guess as to what the problem may be?
Thanks very much,
Jack Coletti
St. Petersburg, FL
Thanks very much,
Jack Coletti
St. Petersburg, FL
