I have a 1996 Johnson 48 SPL with the tilt motor leaking fluid just around the top of the ram. Its coming out really fast only when active, mostly going up. I have the assembly up after a long battle with the two pins holding it in. 20 years in saltwater I guess didn't help. My question is this, what is the usual failure item? I do not really want to buy the $90 oring kit and rebuild everything. Is there a site that sells the seals individually?
I found this schematic online and I believe it to be my unit.
