tilt mechanism
trav44
hi, i have recently ourchased a 1970's merc 402 and i do not understand the tilt mechanism, when i try to raise the engine it seems like it is locked onto the bar, how do u raise it? is there a locking mechanism somewhere? i can only lift it if i remove the trim bar, any help. photos or diagrams much appreciated.
jimmy57
Re: tilt mechanism
probably locks in nuetral and reverse put it in forward gear and it should unlock from tilt pin
Wingedwheel
Re: tilt mechanism
yep, what jimmy said. the lock is to keep the motor from flying up when in rev. It should come right up when you put it in FWD.
